T
Thurgood
Thought I would fool around with this, maybe fun could be bad. If anyone has sugesstions chime in. I do not believe there would be problems if make up gain is set to unity (as preamp section would be passing same db signal if it weren't there) I think
. My theory is that the compression applied would smooth out the dynamics a bit depending on ratio or really kill a good dynamic tone (we all love in tube amps). Just an experiment. Kinda like putting a comp on an efects send of a console instead of the pre insert point. I jsut dont want to fry anything, that's why I believe that the comps output should be unity with input and not pushing to much signal to the power section. BTW the amp is a dsl 100 (turned way down). Second I am not sure but I (once again poss. wrong) that the effects return is prior to the PI. (should be). So with that thinking would I in effect be overdriving the PI tube if more than unity? I can only imamgine waht a overdriven pi sounds like or is that a good thing?? Dunno. Please comment ( and maybe save an amp if trouble!) THnks, Be well all.
