J
jnorman
1) if i move to a digital system, will i still need/want to use compression on piano and acoustic strings while recording the original tracks, or should i record a perfectly unaffected signal from the mic?
2) do the software packages have compression available, or do i need to use outboard gear between the mic and the recorder?
3) whether i compress or not up front, should i compress at mixdown, or only during mastering?
4) how hot a signal should i be able to get prior to mastering? should i be able to match commercial CD levels prior to mastering?
5) if i have to buy two more mics to record a grand piano, should i go with small diaphragms or large (ie, akg c1000s vs c3000)
