M
malgovert
Member
I have been following dachay2tnr's thread in the cw forum re this topic - from which I have learned a lot - however this is the situation: I have a final mix, exported in .wav format, which for the most part hovers around -18db and -12db - in other words it is too quiet. It consists of just two acoustic guitars and a some vocals. it's loudest point is around -5db. Given that the final mix should be compressed in order to raise the overall volume I am not sure where to go next - what I have tried (in sound forge) is raising the volume first by about 12db (which makes it distorted) and then trying to compress it. however I have no clue which compressor settings to use - and none of them seem to make it sound any good. The best one I could find was a softknee with threshold of -24db at ratio 2:1 (do i hear you laughing into your coffee
). I have a book that suggests always using -6db at 4:1 if you are not sure - but this doesn't seem to have any effect - every setting i try leaves it still sounding really distorted or 'squashed', or both. Is there any kind of ballpark setting I could apply for a final mix of this kind? or am i going about it the wrong way? Should i be compressing first then raising the volume? I'm sure there must be a way but i can't figure it out... Thanks. malgo.
