R
RobManYou
Should I def. get a compresser for my vocals or no? If so... what does a compresser do exactly? Does force everything to stay at the same decibal level?
Farview said:If you are recording to a computer and you are not familiar with compression, you would be best off not compressing while recording. Using a compressor plugin during mixdown allows you to experiment without taking the chance of screwing up a good performance.
If you record with your levels low enough and practice proper mic technique, you won't have to worry about peaking and clipping the convertors.
Farview said:The point is, you shouldn't be using a compressor to keep from clipping the converters. If you are clipping , you are recording too hot or you have no mic control. Just turn down the input. Then you can use the compressor to make things sit in the mix better or just for the coloring.
Farview said:The compressor doesn't know if you're singing live or sending a recorded signal to it. It will do the same thing either way.
The reason people tell you to use one before the converters is to avoid clipping the converters. There are better and less destructive ways of not clipping, so there is no need for it.
