H
hubble
I apologize for my long question:
Do you recommend compressing each individual track seperately or is it better to focus on adding compression to groups. For instance a group of drums or a master compression over the entire mix.
Here's what I'm getting at. Most of my Fruity Loops projects always sound amazing to me. They're always crystal clear and loud. I THINK that might be because I'm dealing with samples that I have already pre-compressed, equalized, and saved. So in the program, the master mix doesn't need to be re-processed in order to sound good. Compare this to my live band recordings in Cubase SX3 where I have to struggle to clear things up.
Can this concept be applied to live music as long as everything is isolated and multitracked? Should I just compress and eq EACH track and then freeze the track that way and not worry so much about the sub-group and/or mastering compression?
And do you think this approach would help maintain a "transparent" and consistent sound where the mix doesn't sound squished?
Thanks for any opinions.
) imply : Begin with mixing and volume automation first. Gain riding does not kill off the transient. -see how far it can be taken. Then go after the obvious dynamic issues at the track level. Look at it at two general levels- Peak reductions to reign in top swings, or compression for effect and shaping?
