miroslav
Cosmic Cowboy
Some people don't like the click sounds because they are to synthetic or they feel the click is too "accurate". I think this could best be compared to a drummer listening to the click instead of just going with it. The performance lags or sounds unnatural.
This is the heart of the issue.
Most people that haven't played with clicks enough...tend to listen to and focus on following the click....instead of just playing with it same as they would with other musicians!
All it takes is a bit of getting use to hearing the click...and then it "melts away" but still provides a timing reference. You are still able to drift/sway in and around the click's beat!!!
I don't really understand why the "adding other band members" thing seems to you like such a sure recipe for timing disaster if a click isn't used. I mean sure, if some or all of the band members completely suck... but with a modest level of ability I don't see how it HAS to be such a big deal.
It doesn't.
I already said...if the band is tight, it's not a problem.
As long as a song is well-rehearsed before it is recorded, any slight speed-ups or slow-downs will by that point be kind of "baked" into the song and therefore the other musicians should "feel" them coming when laying down their respective overdubs.
You are assuming that those speed-ups or slow-downs are always going to happen at the same spot and in the same degree by every member.
Sure...if you actually rehears it that way...but often speed fluctuation happen randomly.
Sometimes it takes one member to lag behind or speed up in a critical transition, and it will force everyone else to do that same, but randomly.
It's not like everyone will slow down or speed up note for note in unison...
...and that is NOT *groove*, IMO...that's sloppy playing.
Now...you can say it's not bad enough to be noticed, and that may be so, but to me, if it's noticeable, I'm not going to call it *groove*...and I'm going to then turn on a click to prevent that.
That way, if one guy goes off...the other are hopefully playing with the click and not following that one guy.
Hey..it's no different with tuning/singing. Some guys can't hear when they are 20-30 cents off, so they don't see a need to tune.
But I’m not sure why or what people are really objecting to.
If you think the timing is tight enough without a click…then don’t use it.
For songs that have a solid, steady beat, with no timing changes/transitions…I prefer that beat to be tight, which a click will help with…and that doesn’t mean it has to be stiff/rigid/robotic.
It’s only like that when people play it like that.
You don't neccassarilly want to wear headphones with a click in them when it's time to play live and re-produce those tunes you played so tightly in the studio.
