I
int3rsc0p3
I'm planning on recording classical piano. Would I benefit from the audio interfaces that send each seperate channel to the computer, or would a mixer be fine as well?
I'd go with the two channel Apogee Duet...
and then you can stereo mic the piano...and not have it ruined by a terrible interface![]()
Thanks. Do you know if the IO14 has phantom power for each port?
Do you want to record more than 2 channels at a time? I think you could get a decent sound with 1 or 2 mics, so a mixer would be fine for that particular application. I'd get one that doesn't run thru a PC soundcard, ie a mixer with usb or firewire, that'd be a cleaner signal.
