(*--Broken-spacebar-guys)
Hey-Billisa,
You-can-somewhat-improve-your-"Booth"-by-using-PVC--"T's"-and-"Right-Angles..45's?",so-that-the-blankets-are-hanging-on-PVC-and-not-wire.--(Just-think-of-how-it'd-fit-together-with-two-parts-of-the-T-making-the-corners-and-the-third-accepting-a-Right-Angle-to-go-straight-up.--So,-it'd-be-8-of-each-and-then-the-additional-straight-PVC-cut-to-height-,width-and-depth-of-the-"Box".)
This-extra-support-will-also-allow-you-to-make-and-hang-
a-panel-or-two-of-wood-(Or-some-hard-material)-inside-the-structure-if-you-want-to-add-(or-remove)-the-slightest-bit-of-reflection-inside-depending-what-you're-after.
The-extra-support-will-also-let-you-roof-the-box-with-material-(Like-Peg-board)-that-you-can-put-a-light-in/on...Those-little-round-battery-"Press-lites"-work-great-for-reading-lyrics-in-the-dark.
