N
Neptune
This CDR has a Monitor mode, in which the incoming signal is sent to the outputs. So, I have a question. I have the POD Pro from Line 6, and it has the coax digital connections. And I'm getting the Fostex VF-16 wich has the optical digital connections. The CD-RW700 has both coax and optical. Can I run the POD Pro into the CD-RW700's coax in, and run the CD-RW700's optical out into the VF-16, to record digital direct? Using the CD-RW700 as just a signal converter?
