Cassettes
  • Thread starter Thread starter davidscull
D
davidscull
My band has just put our first song onto tape using a tasc am 8 track recorder. We only used the first 4 Tracks (Lead Guitar 1, Drums 2, Vocals 3, Bass 4) when played back through the headphones on the multitracker you can hear all 4 tracks but whem played back through a stereo you can only hear the Lead and Drums (Tracks 1+2) Please help.
Is this the same cassette that was used to multitrack? If so, you will have to mix the 8 track cassette down to another cassette, assigning all 4 tracks to the stereo output.
Emeric
Hi Just a thought on your layout on the tracks. It might be better to put the drums on trk 1 instead of two. Might stop any nasty bleed through. You now have the vocals between the drums and bass, two big noise makers. Just a thought
Heres a little basic multitrack cassette recorder theory. To keep things simple, I'll speak in terms of a four track. Eight tracks work the same way, the tracks are just 'thinner'. Your standard tape is already designed to be used with four tracks. These four tracks are side1 left, side1 right, side2left, and side2right. When you play something in your stereo, it only looks at two of the tracks, one for the left speaker and one for the right speaker. When you flip the tape to side 2, you're now listening to tracks three and four. Your multitracker, on the other hand, can look at all four tracks at once, and records all 4 in the same direction. To make something thats listenable on a normal stereo, you need to 'mix down' your recording. Your manual should have a description of how to do this. Try this for fun: take a standard stereo recording (one of those eighties metal albums that supposedly has subliminal messages is always great fun) and pop it into your multiracker. turn off tracks 1 and 2, and just listen to 3 and 4. You'll find yourself listening to side two of the tape, only backwards.
-Nate K
