SouthSIDE Glen
independentrecording.net
Sometimes it *was* intentional, other times they had little choice. I can't speak specifically to Revolver (or FTM, specifically to any specific album), but a lot of the early 60's stuff, including, I believe some early Beatles has everything LCR for two reasons:I know it was totally unintentional, but this is pretty much how all of the mid-career Beatle stuff turned out(LCR).
First, because often that's all some of their mixing desks were capable of. While this was not always the case, there were early desks who's "pan" controls were simply three-position switches, and not full potentiometers.
Second, back when stereophonic was new, there was not only a real infatuation with hard panning in order to emphasize the fact that it *was* stereo, but there were marketing reasons too. Kind of like what Kats said a couple of posts ago about "give 'em" the full thrill". It WAS a real "boss" (translation: "k3wl"
) to make the most out of the new stereo effect. (Then add some pot and a tab of acid and, well...just ask Alice
)But also, there was a bit of marketing pressure there too. Stereophonic vinyl pressings used to cost more than mono ones, and both were sold in the the same store bins. Also stereo equipment had to be bought to play these new stereo albums.
While some classical and jazz labels (and their listeners) liked the idea of creating a "natural" stereo reproduction, most pop labels and their listeners wanted to emphasize the stereophonic idea to an extreme in order to create the maximum difference between a stereo pressing and a mono one. Since pop listeners thought this was "boss" too, this helped make the case for spending money on both the new stereo gear and the higher-cost stereo vinyl pressings.
I think it makes perfect sense, IMHO.The canvas doesn't have to be a picture perfect live snapshot, but it doesn't have to be some wacky avant-garde modern paint splatter either. Mix and match. Make it sound cool.
That probably made no sense....
It's not that I think there's anything "wrong" with hard-panning. I put stuff on the edges just like the next guy. And like I mentioned a long time ago early in this thread, because of this thread I set aside an entire evening with my headphones and my primary personal playlist, which is a collection of several hundred cuts of a very ecclectic mix of music styles covering at least 80 years of pro recording. I skipped the early mono stuff and just listened to what was recorded in stereo, and I was shocked to realize the large percentage of stuff that was actually LCR mixed. So it is a common technique. While I think much of the reason for that is a matter of studio time and cost than artistic decision, it is none the less used often and often times with very good results.
I just see it as, like gecko says, very limiting both creatively and technically. But even more than that, it's a concept that just seems so alien when looked at from the "canvas" perspective. Whether one mixes with 4D in mind or not, the fact remains that those 4 dimensions exist. Even if one mixes in mono with limited frequency resonse and leaves it there, that is still a choice made within in the four dimensions.
The four aural dimensions exist whether are conscious of them or view them from that perspective or not. All the 4D approach does is to say, OK, they are there, and when you start out they are all empty (silent). Nobody says you *have* to fill up every square inch of the canvas; just like in music where the rests are just as important as the notes, in mixing the empty spaces are just as important as the sound. But this is the aural space that is being offered to you to use as you see fit. Given the song, the arrangement, and the trackings that you have as your subject material and paint, how can you use this space to compliment and make the most out of that as you can?
While LCR panning scemes can and often do sound just fine, when asking the 4D question above, how often does "keep everything at the cardinal points" really wind up being the optimum answer? It just looks like a very limiting and synthetic construct that has nothing to do with the subject material and the paint one is woking with.
G.
