Can't get the distortion sound I want out of the PODxt or the V-amp
  • Thread starter Thread starter dogbiscuit
D
dogbiscuit
I am trying to record all my own songs on my pc. It's going ok except I really can't get the Heavy sound I want from the PODxt. I'd like a good meaty distortion like green day perhaps but everything I try just sounds shit. Micing up is not an option for me. I have tried the V-amp 2 and now the PODxt. The clean sounds work ok for me but it's just this heavy sound I can't get. Any tips for me? It would be much appreciated.
You will be more than likely stuck with shit sound from either of those. There are some around here that say they can get a good heavy sound out of them but I've heard VERY few examples to prove otherwise. IMO it's a case that they got lucky and the particular patch they used just happened to fit the song. Good luck.
look for an amp with one good sound
not a "merical" with 400
Cheers dawg
I guess I'd be worried if people start saying they are getting a good heavy sound out of these cause that would mean I am doing something far wrong! I think it probably does depend on the paricular song as it kind of works for some but especially not on one. It would have to be my favourite one too!! I am absolutely running out of ideas what to try with it.
Here's just a suggestion. I don't have the POD but I do have a J-Station(it sounds like ass too). Pick a Marshall or Mesa preset. Turn the gain down to about half, bass down around 2, mids about half, and treb 3-4. That's where I normally start. I don't ever use it for more than scratch tracks but it's nice to sound halfway decent.
The best your going to do on a PodXT is to crank the volume all the way up and then control the overall volume with your output nob.
i borrowed a pod about a year and a half back, and i dont recall getting great meaty sounds out of it although i went to see this amazing band (check em out www.trailer-park-trash.co.uk) and the 2 guitarists both played via pods (one used some sort of tube amp as well i mite add) and they got these amazing sounds. they were kind of a hybrid between guns n roses and 70s metal stuff. ive also got their album, which i no was recorded with pods, a bass pod and an electronic drum kit, and theyve captured that amazing sound again. so yeah i duno how they did it but it must be possible.
I use a Pod XT, and disagree completely about getting shit tones with it. Have you got the metal pack yet? It's a must. Go to the Line6 message boards - some of those people are obsessed with tone and tweaking.
http://line6.com/cgi-bin/ultimatebb.cgi?ubb=forum&f=3
I've heard stuff on the XT that destroys most sub-professional metal recordings.
I can get pretty good heavy tones out of a Pod, but I'm afraid my tactics won't be much use to you. I jack it into a power amp, then to a Marshall cab, then mic the cab.-Richie
No amp sim is a catch all. You have to think of it as being just a part of the sound, the same way an amp/speaker/mic is just part of the overall sound. No amp sim will give you the sound you want all by it's self. You have to treat it he same way you would treat using a regualr rig in a recording, only smaller and a lot less noisy. Double tracking, compression, layering, eq-ing, reverd, etc..... you still have to go through a lot to get the sound you want.
IMHO, the prob with the sims is always the same:
The sound is too perfect alone but will not cut through in the mix. Downloaded the example, and it is a good example. Too much high end, too much distortion, too much 'single track fancies' (like verb on the track).
Just back off, less distortion, less high end, no ambience from the sims... Will sound VERY clean and sterile nevertheless. I LIKE the sound of sims as one track of doubled ones. If done right, it can help a lot in giving good definition to the doubled guitars (but maybe I'm too stupid to get that done with 'real' guitar sounds ;) )
aXel
aXel[/QUOTE]
Funny you should say that cause the name of the song Im trying to nail is 'Too Stupid'! :)
I always end up going through most of my options. Face it, there ain't just one PERFECT sound: there are sounds that work, and sounds that don't work. So I try a distortion box, then a tube amp set on overdrive, then maybe another amp, and I may even (gasp!) try a different guitar. A jack of all trades is known for being the master of none.
I've tried digital amp simulators for a long time and gave up. There simply is no way for digital medium to produce the sound of a tube amp pushing air through a speaker. If you want a distorted guitar tone to sit in the mix and sound good your best option is a tube amp and a mic. For $300 you can likely get a small used amp and a SM57 mic.
There's no way you are going to get as good a recording with a $300 amp/mic combo as you would with a V-AMP2 or a POD. Not unless you find a 1 in a million deal or are a recording genius.
Amra
Cheers for the tip. You have swayed me into buying the metal pack. I have considered it before but thought it might just be a gimmick but I think I will give it a try now. They apparently offer your money back if you're not happy with it too.
