The insane option
Firstly, what are you recording into? If it's a computer, I have a suggestion...
I recently worked for a producer called James Sanger, who had a peculiar method for recording drums, but it seemed to work - he used one (you read that right... ONE) mic set up in front of the kit, pointing at the snare, centrally between and at the same level as the crash and ride. Once recorded, he'd use samples to back up the kick.
If you don't want to go quite so far, though, there's a compromise: record your drums into the computer with one of the mic set-ups suggested by mikeh, then reinforce your hits where necessary with samples. This might help compensate for poor sound quality, if there is any.
One draw-back, though - if you're going to use this method, either you're going to have play to a click track like
an automaton, with every single beat in exactly the right place, right down to the tick, or you'll need to tighten your drums in a sequencer (which is time-consuming, boring and not always possible unless you have the right software).
If, however, you're not using a computer, then please ignore everything I've said because it'll be of no use to you whatsoever.
