Can we do "shelving" with the DP-24?
  • Thread starter Thread starter NotThatBright
N
NotThatBright
Obviously this is the screen we have to work with when EQing tracks:
Suppose I wanted everything from 450 Hz and below to be at -2. There's no way to do that with the DP-24, correct?
It Shure looks looks that's a shelving low filter in the picture isn't it? How high does it go?
You know what? I never bothered to even look at the graph on the top left of that picture. As I play around with the frequencies now, I can tell by the graph that the bottom EQ value does do shelving. And the top EQ does the same thing, but with the upper frequencies (I don't know if it's still called a shelf when you're talking about frequencies going UP as opposed to DOWN).
Thanks for the reply.
To answer your question, it goes up to 1.6 kHz.
There you go then.
"I don't know if it's still called a shelf when you're talking about frequencies going UP as opposed to DOWN). "
Not sure I get what you mean by 'frequencies going up' but a low shelf, +/- on the freqs below the set point, and a high +/- on the frequencies above it's set point. Set for about 100 and around 10k and you have the typical Hifi's 'bass and treble tone controls.
