Too much bass usually creates pumping. Or trying to make something as loud as a red hot chilli peppers album.
If the mix is just bass heavy, gotta find out where and make a gentle broad cut.
Another option - use a multi band compressor to control the bass. First band cut off of 160hz. Ratio of 2, attack and release of 100ms, and tweak the threshold until you see some reduction. Don't compensate for the reduction.
If you have a hot mix, start with the threshold at -10 across the multiband. It's fine to remove all but the bass and one other band for this purpose. If nothing is happening, lower to -15.
I like to use three bands. One cutting of at 160 for the lows, another cutting off at 3.5 kHz for mids. The third band is everything above 3.5khz. I use the same settings across all of the bands.
