Fmmahoganyrush
Pleads the 5th...
OK here's the deal. I have an Ovation Deacon (solid body electric) with humbucking pickups. The thing sat idle for a LONG time, and it seems that the pickups have lost a bit of punch. The sustain, especially when doing a lead up the neck, really drops off (much more than I remember). This guitar has a built in pre-amp which is powered by two 9 volt batteries. So I says to myself... ...an electro-magnet is simply a peice of, say, steel, with a copper wire coiled around it and with DC voltage attached to it. So I thinks to myself... ...A pickup is basically the same thing, and if I put fresh batteries in the guitar and leave it plugged in (to power up the pre amp), the voltage should run back through the pickups and re-magnatize them? Sound nuts? It does seem to be working, as I've left it plugged in for a couple of days now. Any body out there know anything about the possibility of this actually working? Or am I just imagining this??? Thanx, Tom.
