bouldersoundguy
By not specifying any of the less common variations you are specifying the default.
But there is no "default".
It's a terminology thing. If you mention XLR inputs, everyone jumps to the conclusion we're talking microphone level, but that's just common usage, not any kind of standard.
When we talk microphones, it was common to refer to spaced pairs and coincident pairs, which were the two common techniques used by recordists, engineers and experimenters. Indeed, when we started calling them A/B and X/Y, the 90 degree angle was very common, and the 90 degrees matching the 90 degree separation of X and Y axis on a graph, or video display. X, Y and then Z, all had 90 degree angles at the coincident point. However, there has always been a bit of wiggle room on the horizontal angle, depending on the distance to the sources and the physical width of the sound source. The popular audio recorders have movable mics, but are still referred to as X/Y.
The discussion here is on differences between plainly X/Y techniques. If the X/Y term denotes the separation from a coincident point, then cardioid, super-cardioid, hyper cardioid and figure 8 are all pickup patterns that can be used in X/Y setups. Pick up pattern AND position are the choices, and if they attempt to inhabit the same space, then all these are X/Y. The crossed fig 8 is also X/Y, but Alan Blumlein's baby, named after him.
We're attempting to convince each other that something is this, another thing isn't, and then some things half-way might be.
Spaced is spaced, coincident is coincident - with the advantages and disadvantages of the technique. Then you decide the polar pattern. What you call it hardly matters if it's accurate. You cannot argue with the physics.If you tilt in two fig 8s, then clearly it's still X/Y, but no longer Blumlein, which is always linked to a 90 degree angle. John and I have disagreed on things in the past, with two opinions, but he is just being factual here, because it's a physics thing.
If someone told you to set up an X/Y pair and then left the room, what would you do? I'd set up a cardioid pair at 90°.
Yup...it's terminology (or semantics).
Is there an "official" default? Of course not.
If somebody says "I used an X/Y pair on that" without adding any more detail, do I assume he means SDCs at 90 degrees? Yup.
Thanks - although if someone says XLR, I would not assume a mic. input because they are equally used for line input as well; though I probably would assume he meant a 3-pin XLR rather than the 4 or 5 pin variety.![]()
I wouldn't - I would assess the situation and choose the correct pattern and angle for the job.
Nope - I wouldn't assume that at all.
It's funny, but this thread is the only place where I have seen it assumed that X/Y normally means cardioids at 90˚ - I have never in my life assumed this at all, especially where hyper-cardioids are alo excellent as an X/Y pair.
XLR is not equally used for line unless you eliminate all entry level and low to mid grade pro gear. There are probably lots of people on this forum who have never seen an XLR line connection and don't even know they exist.
The implication, which I thought was obvious, was that one is merely setting up gear for a lead engineer or producer with the authority to decide how it's to be done. In that case with only "X/Y" specified, would you actually take it on yourself to set up a Blumlein?
You're in a small minority.
I only use XLR for line inputs - phono is consumer and jack is for cheap semi-pro.
No, but I would certainly *not* assume cardioids at 90˚
Really? Nobody I know assumes 90˚ cardioids when X/Y is mentioned.
You're an audio engineering 1%-er, as unaware of the real world of everyday audio engineering as the economic 1%-ers are of everyday economic challenges real working people face. To most of us working in rock clubs, small studios or recording at home your preconceptions are irrelevant, even elitist. I don't say this to offend, only to inform.
X/Y equals only cardioids at 90˚
Yep, XLRs are superior for the most part. They don't short signal to ground when inserted or removed.
...but the shorting point is a bit of a non-event?
One useful thing about jacks is the contacts they often provide for other functions. I have always been surprised that no one has done the same for the XLR?
