R
rkruz
Im using the UMIK microphone with Room Equalizer Wizard (REW)test software trying to characterize all 7 audio channels in. I dont have an analog input to use.
REW has a HDMI multi channel approach, using ASIO4ALL v2 that wont work for me as my laptop sound card only has stereo.
But the "Offline" .wav file that REW can create might work if I can create a multi channel version of it........
I'd like to create a .wav file or multiple files originated from REW for "Offline" measurements that I can play from a USB port to test all 7.1 channels .
But REW only creates this "offline" file for the left and right channel only.
Am I missing something in REW or is there other software that would manipulate a offline .wav to create a multi channel version of the REW Offline file? By that I mean repeating the same "offline" file that can be played for each 7.1 channel?
As you probably know the Offline file contains timing info that will allow REW to sync to the test sweep.
Any tips appreciated. Thanks!.
