Can gear go bad?
  • Thread starter Thread starter Jackrip
Big Kenny said:
Sounds like a gain staging problem or, careful here, there's a chance you are singing into the wrong side of the mic. We've all done it once... well YOU"VE all done it once....
As i was reading this i though you were going to say singing into the wrong END of the Mic :D :D :D
I'm voting for "user error."
I guess if you live in the South humidity could be a factor but not very likely.
I would eliminate everything from the chain I could. If you need the pre then test it first with another mic/instrument. Then just add components one at a time (with factory or "neutral" settings) and check for suck/not suck. I'm guessing it's user error with something in your chain, in which case building your rack again from the ground up should help. As someone who sometimes goes weeks without recording, I've found this very useful. I think my studio is haunted and that the ghosts appear in my off time to fuck up my settings.
themindwillnotletgo
Replies
38
Views
3K
themindwillnotletgo
themindwillnotletgo
antonstudio
Replies
7
Views
878
PorterhouseMusic
PorterhouseMusic
David W. Pontius
Replies
21
Views
2K
rob aylestone
rob aylestone
