Yes! And here,s the way to do it
Open the Cakewalk project that you want to edit.
Select the track in the track view by clicking on it. This can be a single track in a multitrack project or a stereo track that you have mixed down within Cakewalk or imported from another location.
Go to Tools ..located in the Tool Bar at the top..and you should see Cool Edit Pro listed at the bottom along with any other wave editing programs that you have loaded on your computer..ex:
Sound Forge, Wavelab etc etc..
When you click on CEP..it will open CEP and load the wave file that you selected in cakewalk..
Edit to your hearts desire...after you have done your editing ..close CEP....it will ask if you want to save changes..select Yes..the program will close out and you will be back in Cakewalk...Cakewalk will then let you know that that the track has changed and would you like to reload it? Click yes..and you are set..If in the above scenario you wanted to save the edited wave file to another location prior to exiting CEP..you simply select the Save as command..rename it..and send it to another location...then exit CEP...
By the way, Cakewalk works this way with most of the wave editor programs..(Sound Forge, Wavelab)
I should warn you..that if you have done a lot of editing to the audio within Cakewalk..for instance punch ins..or loops within the track..the wave editor" MAY" separate all the little pieces and you will have to listen to all of them to find the portion you want to edit ,and if you want to treat them with the same edit ..youre gonna have to do it one by one..this may or may not be true in CEP but does happen in Sound Forge...but the batch converter would be the fix in Sound Forge.
Hope this helps..holla back if you need clarification..or maybe someone else will simplify my explanation
