T
Twiggy
Just curious. Wanted to know what u guys do for cable storage. Trying to keep all my cables neat and in order.
Treeline said:Most of my cables are used for live work, so I have to transport them. I use a simple large plastic toolbox, remove the tray, and keep XLRs coiled in roadie coils held with velcro or florists tape ("velcro lite"). The roadie coil is a loose coil with every other winding in the reverse direction so the wire "wears" evenly - avoids twists inside the jacketing. When done consistently (e.g. always start from the female end) the coil can be cast across the room like a fishing line, where it needs to go. I'm still working on that part. I can get about thirty cables to a box if they're neatly coiled. The boxes end up being modular if you get three or four of them, so each can be marked for a particular type of gear. Marking each box with a big magic marker ("XLR") ("Guitar") and so on helps with setup and tear down time.
. I buy Radio Shack velcro ties, a five pack of red, yellow, green, blue, black for $3. The velcro goes on the female end, in ROYGBIV order. Red=30', Yellow=20', Green=10', Blue=6', Black=50'.
Treeline said:God, you're so organized it makes me sick.
I may pick up a few of those ideas, if you don't mind...![]()
notbradsohner said:2 by 4, screwed into the drywall, with a bunch of 4 inch drywall screws evenly spaced on that. Cables go on the screws.
