Z
Ziller
Wow, thanks a bunch Skippy. That was a great explanation. I knew balanced was better, but not why.
I am interested in this topic at this point, because I need to run a couple of cables from my mixer to my computer, about 20' away. I figure I should use balanced, but like Popcorn, my soundcard only has unbalanced ins. Usually not a problem, except for the distance I have to run the cable. My plan is, at this point, to run 2 balanced cables (L/R) out of my mixer, 20' to my computer, and put 2 of those low z -> high z transformers on the end, then adapt it down into the 1/8" stereo input on the soundcard. From what you explained then, it must be those transformers that do the noise cancelation, before sending the signal out as unbalanced?
Thanks again for your clarification.
Ziller
Ziller
