B
		bigsix964
Hello all,
I am having some trouble figuring out the bouncing / ping pong procedure on my Fostex Model 80 / 450 mixer setup and am hoping someone here is familiar with said gear and can help out. As a primitive example, let's say I have a click track recorded on track 8 and want to send it to 3 instead and erase 8. I should mention now that I have the mixer output connected to the deck's input via the 4 buss method, not the 8 Direct Outs. The Model 80 has channels 5-8 in parallel to 1-4, so the 4 Buss outs can still be printed to 5-8 on the tape machine by simply arming those respective tracks to record instead. I thought that I would be able to set the channel 8 input to "Tape" then assign the playback to Buss 3 and voila, the Buss 3 output should have carried the signal to Ch.3 Input on the Model 80, but this did not work. I'm showing no input signal level on Ch.3 meter of the deck. Obviously there's something I'm missing regarding the signal flow between the individual strips and the 4 groups when the input is set to tape, but I am too new to analog to figure it out on my own. Help!
 I don't think that would work at all because that would give me no control over the gain of the I/O between the channels but I could be wrong.
