SouthSIDE Glen
independentrecording.net
Agreed in principle. I often use my ProVLA for such a purpose as well.Giganova said:I was thinking about using either a tube pre or compressor to drive the signal into slight tube distortion. I understand that this is different than using a tape recorder, but it could give an 'analog' sound & feel without the hassle of tapes (alignment of tape, head cleaning, servicing, etc).
Again, though - and I'll admit that the character of this changes from machine to machine - the degree of warmth is to some degree proportional to the type and level of compression applied. Don't expect to run the signal through a compressor at zero compression "just to run it through the tubes" and get the kind of warmth you're looking for. Sometimes you might get lucky and it will be "right" if you do that. Other times you'll find that the degree of warming you're looking for just isn't there unless you boost the compression ratio or toggle between fast and slow attack.
At that point in the production you gotta decide if there is a trade-off and if it's cost is acceptable: is the amount and character of compression I'm using just to get that tube sound costing me too much in dynamics? If you have to compress the signal more or faster than is otherwise optimum for the master, are you losing in cost of dynamic range as much or more than you are gaining in warmth?
If that cost is too high, then it could be said that the compressor is the wrong tool for that job. You'll still want to use it for actual compression, probably, but you'll have to get the warmth from somewhere else. It's for those situations that analog tape can be a great solution; it can provide that "analog sound" without costing much at all in dynamics.
Now, however, I'd like to ask others to chime in who may have different or more experience with tube compressors than I. Perhaps my problem is with the dual design of the ProVLA? Is the fact that it uses both optical and tube circuitry the reason that I have the experience with it that I do, and that maybe some other pure tube compressors will warm better regardless of attack and ratio settings? I'd sure like to hear, and probably (hopefully) so would Giga (this is his thread, after all.
)G.
