bouncing on hard disk or record to hard disk and sample rate conversion in PROTOOLS
  • Thread starter Thread starter outsider
O
outsider
i have to downmix a 48 khz project in protools, normally i use to record my mix on a new track via an internal bus, but now my projects is at 48 kHz sample rate so i need to convert to 44.1 since have to bun an audio cd, what is the workflow do you suggest? thanks
Bounce to disk, tweakhead slow, 44.1kHz (don't change the bit setting), convert after bounce.
If they're 24 bit open the bounces in a new project, insert dither on the master bus set to 16 bit, bounce again, tweakhead slow, 16 bit, convert after bounce.
