Boss Compact Pedal: PH-3 and Expression Pedal
  • Thread starter Thread starter timmerman
timmerman
timmerman
In the manual of the PH-3 it says that you can use an expression-pedal to make changes in the rate.
Well what I would like is to set the pedal at a high rate and to use the expr.pedal to slow down in rate, let say mid song. However so far I have only been able to change the rate with the expr. pedal, the rate then remains the same, and any changes you will make with the expr. pedal sound crude. So I would like to make subtle changes in the rate, but it seem that the expr. pedal will not allow me to do so.
I have tried different Boss expr. pedals and also other pedals with a high and low impedance output, but until now without any success.
Is there anyone here who knows more about it? Am I overlooking something, or perhaps do I want to much from the pedal?
Eddie de Timmerman
