I
i_jr_i
Ok, I have a question on the recording booth foam.
I read that I can use nails and glue.
I'm thinking of using screws.
Now, If I was to use it with a drill will the foam rip? Cuz I was thinking of measuring the foam, and making the holes with the screws and the drill, and then coming back and screwing the screws with a screwdriver, I'm going to put as much hard labor as I can into my booth.
Now, If its easier with nails, what type of nails will should I use, and is it easy to remove incase I have to move?
I belive that the walls are Dry Walls, Not entirly sure. But please specify the size and name of nails and screws, ect. Thank you, Very Appreciated
