RICK FITZPATRICK
We'll just leave it at that unless you want to break out your slide rule and talk wave propagation physics.
We all do in the end FitZ.Dang Frank, your turning into a crudgmudgen like me.
Well, after reading some of my crudgmudgen posts, at least you'll know what NOT to become.We all do in the end FitZ.
Hey Frank, compared to me you're still a pup!I'm turning 40 in two months.
Well, after reading some of my crudgmudgen posts, at least you'll know what NOT to become.btw, I'm trying to be a good member now.
They're great for standing waves and flutter echos, two of the biggest problems home recordists face. So I don't understand the outright bashing of them in a forum about home recording. However, as was pointed out, bass traps are the other part - Auralex recommends you use their acoustic foam WITH bass traps if you want to tame the whole room.
I like Jeff_D's post. That made sense to me. Again, I'm not an expert. I just don't like over the top bashing of stuff. I like posts more like Jeff's... a well thought out logical opinion.
so I've got a space to do my vocals it's a large as storage closet but the problem is the echo I'm trying to decide what to put on the walls to help this I have a good condenser mic and an se reflection filter which works amazing i've been doing tons of research and talking to lots of people the space is ready and i don't have tons of money to isolate it i was thinking to use eggshell foam cause yes like i said no money will it help isolate the sound even more frank you look like you know a lot maybe someone here can help because maybe im just over thinking all of this THANKS!
DMysticMC appeared to be talking about isolation. Neither foam or rigid fiberglass will do anything for isolation.Punctuation is your friend.
Eggshell foam is the wrong stuff. It's closed-cell, which makes it unusable for acoustic purposes. The stuff by the big manufacturers is open-cell and higher density, which changes the response completely. Again, foam will do a good job of taming high frequency stuff, and some of that will be necessary even in a small space like that. What's likely to happen though is that you'll wind up with a space that's pretty boomy because the foam will do nothing to control the lower frequency issues. I almost always suggest panels at least 2" thick (which should cover well down to about 250Hz or so), and 4" thick panels are even better. I know space is at a premium, but that's probably what will be necessary.
Frank
Also, not all egg crate foam is closed-cell.
ok guys thanks for the help i got some good 2" foam and used it this was more to just treat the sound i guess i used the wrong words when i said isolate.so i used what you suggested frank and got some bad boy bass traps in there too with all this and the reflection filter it sounds way better and i'm happy with the drier recordings i'm getting with vocals as well as my instruments its great with the software i usually just add a few effects and mix things down to my liking and its just awesome thanks for the help![]()
