easlern
Boredom artist
Hi guys- I've got a BlueTube preamp that I'm suspicious of not having enough phantom power. The pre works fine with mics that don't need phantom power but when I plug in my SM-81 (uses +48v phantom, which the BlueTube has a button for), the sound on the mic cuts out after 20 seconds or so. The mic tests fine on another pre. When I turn the pad on, the mic doesn't seem to cut out but I don't want to constantly use the pad. Am I correct in guessing it's probably a problem with the pre, and has anyone had a similar problem before? I have yet to try using a different outlet for the pre. Could that help? Thanks for any advice!
I have a spare TubePre that I will try it on. I've been using both channels of the BlueTube at the same time without a problem, so the phantom power use is the only variable I can think of.
