Blue Bear - HELP!
  • Thread starter Thread starter eljay
E
eljay
I have this problem with my mixes. They have too much bass rumble!
Do I need a HIGHER compression level? Right now I am compressing at about 6:1 with a fast attack and release.
But all my mixes just have too much rumble!
What would be a good place to start shaving this under lying boom. It makes my speakers flutter. I try my mixes in the car, boom box and home theater.
Everything else I have worked out. The mix sounds warm, clear and sparkly. Just that boom boom rumble at the bottom!
I really need some help here, my deadline for my demo is almost due and I need it done!
More compression would only make the problem MORE obvious....
Can you post a clip to show what you mean? (It's hard to figure out that kind of issue without hearing the problem!)
Without actually hearing it, you could try a simple lo-cut filter (or EQ plug-in, set below 50hz)
Here is a clip
Ok Here is a small clip, it's this one section that just flutters all the systems I try it on.
You just can't get much volume on it or will "bass out"
Am I making too much of this?
This is a clip of the original mix, nothing has been done to it.
HERE THE LINK TO THE SAMPLE:
Use the lo-cut filter.... according to my SA, you do have unnecessary low rumble there that will eat into your headroom....
Start the lo-cut at 60 Hz and work your way down towards 20 Hz until the rumble is gone but your music content is where you want it....
Sound like you've got a ground loop somewhere in your recording chain, or you're picking up low-frequency vibrations from mic'd sources (or a bit of both!)
