D
dmun1
Does anyone have a schematic for a Beyerdynamic CV710N microphone?
I screwed up on those resistance measurements of the transformer.
Should read:
between black and red = 50 ohms
between brown and either red or black = 20 mega ohms, but the meter never really stabilizes.
Doesn't seem right to me, but I don't want to rip apart my other Beyer to take measurements.
That sounds reasonable to me. The output transformer will not be centre-tapped. The brown wire is probably either an internal shield or attaches to the can (you can test if it connects to the can).
Maybe post the tansformer model number here if you want wiring details. I'd be doubtful it's faulty though.
You might want to measure the voltages at the FET in case it has turned faulty. Don't get the top end of the PCB dirty near the Hi-Z area or the mic will become noisy.
Brown = internal shield.
Black/Red = Secondary.
Blue/Yellow = Primary.
The transformer is 1:7 (wied as 7:1 to lower the output impedance and balance) as can be seen here:
As I said before, it's not the most likely part to fail. I'd look elsewhere. And I'd also take your post to the prodigy-pro forum (Group DIY) where there is a lot of knowledge kicking around.
Thanks again. I know it's not the most likely part to fail, but because the brown didn't show any continuity to any other lead, and the previous owner had mentioned that someone had fixed the grounding, I thought it possible that they overheated that lead. That's the trouble with a little knowledge, I guess - it can lead you down the garden path!
