Best room arrangement of 2 options
  • Thread starter Thread starter barakmaimon
B
barakmaimon
Hello,
I have 11 different acoustic panels in different sizes and 4 diffusers, before locating them i would like to arrange my room in the best way possible.
I have 2 options of room arrangement -
(the furnitures size is relative to room size, room height - 8.5 ft)
Imgur: The most awesome images on the Internet
As i understand the first option is better than the second, but the closet will block the entry and will look bad.
So the real question is how bad is the second option from the first?
Thanks.
In a room that small you'll just have to make do. The first way would be better, but you're going to need to treat the front corners (blocking part of the window), and you won't be able to treat the corner with the door, unless you move the trap (assume these are bass traps, and not just "acoustic foam") out of the way when not mixing.
The 2nd picture is not good, because one of your monitors (assume you have them) is going to be stuck right in the corner and it will nto be symmetrical in the room.
Diffusors? Probably a waste of effort in such a small room.
thank you for the answer.
I have bass traps and monitors.
There is nothing i can do with the secnod option even though its not symmetrical?
Can you pleaes explain why diffusors are waste of money in a small room?
Thanks.
