Speeddemon
yeah Grif, I'm a knobs man as well
I'm stuck for now with my Bandit.
I chose it, also because it has 2 indepent EQ's, which I definately need, or do you guys like to share clean and lead with the same 3 knobs? Forget going from Knopfler to Van Halen then!
I needed a wide range of sounds too. Surf, funk, rock, blues, metal, thrash....
When I bought my Bandit, there was no Spider available (jan. '97), If I had to make the choice again, hmmm....hard!
That's why, of all the nice expensive amps I've played, I chose the JCM2000 TSL122, 3 fully indepent channels with each his own EQ, ranging from ultra clean (almost, repeat almost Fender-like) to ultra-gain! ROCK! Even the crunch-channel can make grannies throw up!
Other contender would be Hughes & Kettner Tri-amp. Haven't played it YET, but a good friend of mine has it, loves it.
I needed a wide range of sounds too. Surf, funk, rock, blues, metal, thrash....When I bought my Bandit, there was no Spider available (jan. '97), If I had to make the choice again, hmmm....hard!
Best sounding Marshall I've EVER heard! The downside is you can't play it that loud in any club I've been in. It still sounds good at lower volume, but not like when it's cranked.
