I will just place my opinion here: Whatever you hear about one mic or another on youtube will likely drive you insane, or possibly give you false information. Or maybe good. It is tough for anyone to give advice as to what works for anyone. You will form an opinion yourself from use of whatever it is you purchase. Hopefully you have a good room to make such decisions from.
You set the budget way lower than I would suggest as a starting point, but I looked for things that might work for you. $100 for a mic/mic combo to do both acoustic guitars and vocals without even discussing room acoustics and interface? That will likely result in your recording experience being as bad as you expect if you don't take your room into the equation.
My suggestion for you would be to spend as little as possible until you know what you actually need. A $1000 mic will not sound much better than a $30 mic in a shitty environment.
But then, some think they have found the holy grail with a Rode NT1a. I use mine as a talkback mic for drummer now... One man's treasure is another's waste of time...
Bottom line is that you will find a ton of opinions from users of varying degrees of experience. None of them really mean anything unless you have the exact same recording environment and instruments. Make sense?
Your budget determines your starting point. Your personal desire for quality will determine what you need to do to your budget to make things better once you have experience to make a decision for yourself. I suggest you start small and decide what it is 'you' need from there.
I have learned expensive lessons myself. I hope my rant has not come across as arrogant or judgemental.
Best!
