behringer
  • Thread starter Thread starter walterhawk
W
walterhawk
just got a used behringer compressor mdx 2100..with no instructions..any ideas how my basic setting would be for vocals/drums..thanks
Start with turning it off and see what the basic sound needs. Then see if you can find some basic instructions on compressor usage and see if you understand the impact the compressor (with various settings) might have on your sound and if you need that. First understand what the gear does, then try to use it for specific tasks. Playing around without knowing what I'm doing has cost me plenty of time I could have spend better on my girlfriend or on learning how to play the piano.
Right, there is a tendency at first to overcompress when learning compressors. In many cases, it's not right if you can hear it. Use the bypass switch often to compare the compressed with the uncompressed.
One of the most important controls is the threshold control. This is what determines how much of your material is going to be compressed. So for example, if your program material has peaks that go up to -12, and you set the threshold at -15, then 3 db of your signal is going to be compressed.
The attack and release times are also very important for getting the sound you want from your compressor.
The best thing for you to do is to play around with different settings on different types of music, while listening very carefully. Notice how the sound changes at different settings, and then apply that when mixing your own music. Compression is somethng that takes quite a while to master.
I should clarify that what I said was to help you start to hear the effects of a compressor, not a way to actually use it in a mix. I am a way off really getting compression but training your ears for what to listen out for is worthwhile IMO.
hmm
Steal Sessions said:
Start with turning it off QUOTE]
excuse the excerpt...
hahahaahahahaaathats fhkng got me laughing...
i think this forum has me twisted..now i'm laughing at this kind of sht.
manual
tried?
behringer.com
Support
Downloads
FrankD77
Replies
5
Views
2K
FrankD77
FrankD77
raybbj
Replies
19
Views
2K
Slouching Raymond
Slouching Raymond
J
Replies
9
Views
900
TalismanRich
TalismanRich
B
Replies
11
Views
1K
BaronEstelle
B
M
Replies
5
Views
680
Slouching Raymond
Slouching Raymond
