D
davelivinstone
hi guys,
Sorry if this has been asked, but I couldn't find the info when I did a search. On the VAMPII, can you use multi-effects? I mean, if you dial in Tremelo and set the amount of tremelo that you want, can you then dial in echo and dial in the amount that you want and still have the tremelo active? or when you switch the effect that you have chosen, does it de-activate the effect you were just using?
If you can have multiple effects at a time, what is the limit? can you use all of them at the same time? And if you can have multiple effects, are they added to the signal as a chain or in parallel? I mean a guitar with tremelo and echo in parallel, is not the same as a guitar with a tremelo and echo chained. I downloaded the manual, but I can't seem to tell from the manual. I am thinking of buying a VAMPII but there are none available here for me to test.
Thanks,
Dave
Thanks,
Dave
