Behringer Composer Pro vs. RNC
  • Thread starter Thread starter Tongi
chessrock said:
I don't remember anyone asking your opinion.
Oh c'mon - you should know by now that you don't have to ask -- I give it freely! ;) :p
whatever, its annoying that you so called "senior members" with thousands of posts to your name cant just give quality advice. when i look at other posts, its the "newbies" who give advice around here and try to help and post good questions. its always the senior members who end up starting the shit.
What a load of crap........ :rolleyes:
Please feel free to put me on your ignore list.......... *shrug*
Shut the EFF up newbie or you will be bombed.
tkingen said:
Mosfet,
You quoted my comment about the artificial highend frequency deal, so I decided to add a little more to this thread.
If you want to use Behringer stuff, go ahead...but it's unbecoming to get your feathers rackled if someone disagrees with you. You are correct...lot's of FOH engineers use Behringer. You will find this mostly in local town professional companies. Why? It's cheap to replace, easily available, easily disposable if it breaks, and it does an adequate job, Ask them what would they would prefer to use, and they will most certainly give you a different answer.
As for the real deal pro live sound systems, you will not find Behringer in the live racks for the Rolling Stones, Paul McCartney, Sting, Alan Jackson, etc. Same deal with the "big" recording studios. There is a reason for this...they want a certain quality and can afford it.
As for the artificial high end deal, that is my perception on my system and I stand by it. You should certainly stand by your perception and use whatever you want.
Regards,
Terry
I can overlook much, but this is definately wrong. There are so many pro studios and touring rigs with Behringer stuff in it it even amazes me. Abbey Road has some stuffed in its racks. I have no idea why they use it, but I have seen alot of Berry gear in totally world class pro racks.
Shut up acorec. This matter has ended.
You will be bombed also.
A-Salaam A-Laikum. Wa-A-Laikum Salaam.
Okay, I stand corrected.
Here’s the deal as to why I prefer not to use Behringer gear… Once upon a time I had a 1604vlz that served as the front and back end of my DAW. The outboard gear in my meager rack was a Composer Pro, dbx166, TC Electronics M-One and a midlevel Lexicon reverb.
As an experiment I inserted each piece of gear, one at a time, into the channel inserts of the 1604. The rack gear remained in bypass mode and I played a prerecorded track from the DAW. The Composer Pro, dbx, and M-One all effected the signal of the original track. To check this out, the insert jack was continually removed and put back into the channel insert just to see if my ears were playing tricks on me. Retesting confirmed the results. And remember, each of these pieces of gear were in bypass mode. The Lexi reverb passed the test beautifully. So, the Composer Pro, dbx166, TC Electronics M-One were sold or traded away.
A few months later the decision was made to sell the 1604, use dedicated mic pres and “mix in the box.” So, I purchased some pres and a Behringer 4 channel headphone amp that had main outs to the monitors. It was great! But I started noticing that my mixes weren’t translating as well to other systems. I a/b the Behr with a Presonus HP4 headphone amp that also had a mains out feature. I found that the HP4 was more natural sounding and that the Behr seemed artificially hyped, kind of like an inexpensive Chinese condensor mic. So, the Behr was sold.
Eventually, as my ears matured, I perceived flaws in the HP4. So, it was replaced with a Central Station. The HP4 is a good unit, but the Central Station has better routing options and unequivocally has better fidelity.
Now, does any of this mean that some of the gear is good and some of it bad? Not necessarily…it just means that it didn’t work for my needs and/or expectations. A good engineer can of course achieve great results with any number of lower end gear choices…and they do. 99.99999999% of the time no one will be able to tell which pieces of gear were used to record a song, only that it sounds good. And, I do believe that live sound reinforcement inherently has different requirements than studio recording.
As we’ve all been advised a thousand times…it’s whatever works for you.
Regards,
Terry
