Behringer ada8000
  • Thread starter Thread starter singaporerock
singaporerock
i had recently purchased a behringer ada8000, which unbeknownst to me needed a toslink/ADAT/Lightpipe input to use the 8 outputs. (it just converts the incoming 8 channels from the toslink into an analog signal which then goes out the xlr outs) i have the digital out running into an alesis io26 (which doesn't have a digital out to plug back into the behringer) so to avoid toslink cable splitters and all that, could i just open it up and solder the three connections from the digital out to the three connections for the digital in? or would this short out some internal transistors or something?
i am using an alesis io26, but im more concerned with the internals of the behringer, will they overheat or can i solder these posts together?
