Bass tone has to much treble
  • Thread starter Thread starter Dijon
D
Dijon
Ok. When i go to record my tracks nothing advice. like this band has a song. www.purevolume.com/wordstoliveby "love hasnt lost its way" i dl the song and used a simple recording program audicity its free. All i wanted to do was put bass over there song so they could hear my style. But when i when to record it. it was very trebly and twhanny. I messed with the eq's on both my amp and bass. if i turned the treble down to much you couldnt hear me on the recording so i turned it up a bit. and the twaning came back. so i turned it down again and turned up the volume on the amp and then the bass was to overpowering and you couldnt hear anything else. I just think it could be cause im trying to use the mic that came with my computer. and my amp is a P.O.S. but still do you have any suggestions?
I would find it really hard to record a bass part over that recording. It is soo muddy and lo end heavy. Its so muffled and messy.
Try playing with the EQ of the track before recording a bass part over it. Take some lo and lo mids away so there is room for your bass to be heard.
Once the bass is recorded, compress it pretty hard which will make it sit in the mix better. Not sure what you can do about your tone though. Only thing you can do is play about with the settings and if you still cant get a good tone without too much treble then im not sure what you could do really! or buy some new equipment.
You answered your own question. The main problem is that the mic that came with your computer is most likely only suitable for spoken voice recordings. If your budget is zero, you can try plugging the bass into the line input on your computer. (I guess you would need to spend a small amount on an adapter to make that connection; I don't see any way to avoid that.) This will not be ideal, but should give you a better tone that you are getting now.
Don
How is the rest of your EQ curve set? I see a lot of people making the same mistake as they do with guitars- not enough mids, so the lows and highs are too much. You get mud and twang, with no definition. On that clip, it sounds kind of like too much low end.
Start off with amp and instrument EQ flat, see where that gets you.
Here's a tip you might try from Carol Kaye's website:
tip 100
Hi Jeff! And thanks. About muting: The way I mute the strings is by folding over a piece of felt muting (buy at the sewing section at Target, Walmart etc.) so it's doubled to a width of about 1-1/2". Take it and tape it (I use masking tape) to on top of the bridge area, but laying slightly ahead of the bridges. It won't be too loose but you will have to re-tape it tighter from time to time. Thus, it lays on top of the strings and kills the over- and under-tones, making your bass sounds more defined. You use a doubled up piece of felt *on top* of the strings when you play *only* with a pick. If you play with fingers (or even with fingers sometime and then pick sometime), then get a piece of foam about the same width, but fit *underneath* the strings, barely touching the strings. This takes some doing. You don't want the foam to mute the strings so much it gives off a "plunk" sound, yet you need it to touch all the strings relatively the same amount. The strings in all instances should ring almost as much as if there wasn't any muting at all. You'll notice an immediate difference in sound and your band will too as well as the audience noticing the bass sounding great and projecting very well too. In recording, it's a must. If you have a bridge cover and are using a doubled up piece of felt, lay it between the that rubber "mute" (that is practically useless) in the bridge cover and the strings, but....do raise the bridge-cover slightly so the strings ring....you will have to stick a couple of wedges underneath the bridge-cover so it stays up without rattling (I always used 2-3 picks). This is the sound you want, a ringing sound but without all the extraneous noises of over- and under-tones the strings get. This will work fine. You'll see my mute (with the "fancy" masking tape) in my pictures with the Aria Pro II (Steve Bailey bass), my bass w/Seymour Duncan Basslines PUs and Thomastik jazz flats.
Ya this is the way i went about it but i think that i didnt cut the mids to much but i dont like the mids up to high it doesnt sound right. and i had the bass reallly high like you said tremble was low to really high i moved it around to try to stop that twang
