Seafroggys
Alright, so I want to build a bass drum tunnel. But not for the normal reasons. I'm not trying to extend the bass.
What I want to use is a condenser mic on the bass drum (an AT4047, for those wondering). I've recorded it before, it sounds really killer. But there is one problem. It captures way too much cymbal. I'm not talking about regular bleed. I'm talking the cymbals are half the signal, and the mic is freaking 3" in front of the drum front head. If I boost any highs on the bass mic, the cymbals instantly jump out on the full mix, and not in a good way.
I've used thick blankets before, but they honestly don't work that well, and aren't steady. And don't look sexy. Would building, say, a circular bass trap be the way to go? Or at least a 5 sided bass trap that sits on the ground like this:
.__
I....I (ignore the periods)
Would that provide sufficient mass to block out the cymbals? Or is it overkill? Remember, I'm not trying to treat the bass drum itself, I'm just trying to isolate as much of the cymbals as I can, given that this is probably the most optimal mic placement I can achieve. I'm not isolating the otherway, and the overheads tend to pick up the batter head anyway rather than the resonant head.
.__
