cusebassman
Freakin' sweet
Hello all - I've been recording electric bass DI-only up til now. First I was recording it straight into a Tascam 2488, and then when I upgraded my outboard pres and compressors, I started recording through a JDK Audio preamp and compressor and then into the 2488. The ultimate sound isn't bad, per se - the basses I'm using both have active preamps with 3-band EQ, so I can taylor the sound pretty well so it sits under a mix. I am having a few issues though:
1) I don't much enjoy the tone of the fretless 6-string Carvin bass I have when run through either of the above setups. Even with onboard EQ, I'd like more tone shaping before recording.
2) Even when playing my fretted 5 string (Ibanez SR485) with a pick, there is little definition to the bass sitting in a mix. While this is often desirable, there are occassions where I'd again like more tone shaping possibilities when the bass should stand out more.
So my question is, in an untreated apartment where I could potentially play through an amp at moderate volume to record, would it make sense to get a bass amp and mic it, or get a more advanced bass DI with amp modeling, etc? If you suggest either, please feel free to make specific recommendations. I'd be happy spending 500-600 on this, but probably not much more since I am getting by *okay* for the time-being with straight DI.
