Disco_Dave
I am currently buying a new house. The place I am moving to is an old terraced house (150 yrs old) with nice thick walls. The room at the front on the basement level is going to be my music room, it has a window which is below street level and a wooden pannelled floor and underneath that is terra firma.
My plan is to put a second pane of thick glass on the inside of the current single pane window (which doesn't open anyway). I would seal this properly and could even add shutters to reduce sound transmission even further while allowing natural light in when playing at low volume.
I don't intend to touch the ceiling at all as it is a house and the room above will be mine. I also figure the floor can stay unadjusted too (particulalry as I think the wood will be good acoustically.
As for the walls that join the neighbours...I intend to create a half stud wall with 2 by 4 seperated from the existing wall with strips of rubber or neoprene, filled in with mineral wool and with two layers of gyproc on top...with all the gaps sealed and the edges offset.
What i would like to know is will this make a noticeable difference. I'm well aware that this is a low cost simple solution but is it worth doing for the benefits I will get? Furthermore does anyone have any further suggestions? I'm only intersted in noise reduction at the moment...I know quite a lot about acoustic treatment and am still planning that.
