JimmyS1969
MOODerator
Sizzle and then burn! LOL!
Sizzle and then burn! LOL!![]()
You mean the question about is there a resistor network? We did that. The problem is that to bring the impedance down, this network would pad the speakers. A 6 Ohm resistor in parallel with the speaker would do the trick electrically, bringing the impedance down to just over 4 Ohms - BUT - nearly ¾ the power output would be converted into heat - so the resistor would need to be big enough to dissipate this - and power capable resistors are not very small! you also are wasting three quarters of the amps power too, so it's a pretty poor solution.
So you're saying you'd need something on the order of a dummy load.
Thanks. That was a good explanation. I read every word and picked up a bit more wisdom.The amp won't get hot because it sees the load in the same way as it would see a speaker.
I'll try to explain how the loss of volume works.
We need to simplify the explanation a bit - but it's the old question of multiple speakers. Two 15 Ohm speaker cabinets daisy chained together in parallel have an impedance of 7.5 Ohms - handy for the 8 Ohm output amp - good matching, full amp output divided between the two cabs. Add two more of these cabs and the impedance drops to 3.75 Ohms, close to the 4 Ohm amp's requirement (a tiny bit low - but of course all that cable probably amounts to maybe another half an Ohm.)
All the amp power goes to the 4 speakers. If we remove one cabinet and replace it with a nice big chunky resistor that is 15 Ohms then we've removed a 15 Ohm speaker and swapped it for a 15 Ohm resistor - the amp sees no change at all - BUT - resistors make no sound, so the missing cabinet's output sound is gone. Do the same with two more cabs, replacing these with 15 Ohm resistors, and it leaves just one cabinet producing sound, but four things dissipating the energy from the amp. remember that this energy MUST go somewhere - 25% turns into sound from the working cabinet, but 75% of the energy turns into heat. Hence the volume drop. The amp is perfectly happy. It can object of the volume is too low, so you turn up to 11 of course.
In practice these figures are slightly different, because some energy is converted into heat in the speaker coil and some is even turned into heat in the cable - but the physics is essentially correct. Purists will also want to point out the other differences in sound compared to simple DC resistance - but these components are small and confuse the understanding.
On the what makes speakers a certain value - you got it. The number of turns, and the diameter of the wire used set the impedance value. As power levels go up, the windings get chunkier because the current requirements go up. Current is the key - not so much voltage. A welder uses quite thick cable at a low voltage, those power cables across fields might well be 11 thousand volts, but are thinner than the welding cable. If they distributed power at a lower voltage, higher current, then more would be wasted as heat, and would be heavier and far more expensive. Speaker manufacturers design their products to suit the need. Those old speakers in the much loved twin cabs - the Vox and Fenders, for example - they sounded nice, but weren't mega loud. The drivers in Marshall guitar amps were louder but sounded different - different cone sizes, power handling and wire sizes all combine.
Is this a valve amp?
If so there may be a multi impedance output transformer that you can select output ohms on my using a different transformer tap?
I seem to remember we did this back in the 1970's when we added 2 extra speakers to a valve PA head. The electrical guy in the band figured this out.
Alan.
Can I make a suggestion,
Keep the speakers you have and go out and buy a compact 4 ohm bass cab for the smaller gigs.
I am a bass player and I own several amps and cabs of various sizes and I take the amp that suits the gig. However as I am not getting any younger I tend to take the compact lightest amp with me these days
Alan.
Yeah, thanks Allen, that's most likely what I'll do. The monster cab actually sounds very good, it just lacks in portability. It's almost SVT size.![]()
In my studio it'll be great. Also, it sounds very good with my 4 ohm Showman head.
Most likely I'll just build a 1x15 cab for the bass head. I just have to find an appropriate speaker.
As to the Showman, did mention, also 4 ohm? I have a 2×12 matching cab. Again, I need speakers. But in that case, 2 8 ohm speakers are easy to wire up for 4 ohms.
I have no issue with building and tolexing cabs, it's the buying of speakers I was trying to avoid.![]()
http://www.lean-business.co.uk/esho...MIm6KzvpOC3AIVaL7tCh1M0QzFEAYYASABEgL84PD_BwE
^ Or, you might pickup a decent 4 Ohm car woofer from a ICE fitter or scrapyard for less?
I'm thinking about building a closed back ported cab.
Looks like a nice speaker. Dave.I'm thinking about building a closed back ported cab.
Ps. What in the hell is an ICE fitter?
Car speaker? No way! Were you talking to Dave?Car stereo speaker?
Get a professional speaker designed for bass guitar not something they say is rated at 1000watts or whatever but is really about 10 watts.
Alan.
Car speaker? No way! Were you talking to Dave?![]()
