		singlecoil
To give me a reference point EQ wise for monitoring my own material, I
play some well produced commercial CD's thru my board+power
amp+monitors to hear what I should aim for EQ wise. Problem is, I
have to add high and low EQ for these to sound similarly good like thru
my home stereo which has the treble and bass boosted as I am used to
hearing them. With no EQ they just sound dull and low on bass. So, do
I listen to these CD's with board EQ or without board EQ. Then should I
then try to make my mixes sound similar to the unEQ'ed CDs or the
EQ'ed CD's? Or, should I listen to the CD's on my home stereo and try
to get a similar sound with my material thru my board? OR, should I
monitor thru my stereo reciever with it's EQ on like how I usually listen
to it? I never have read anyone discuss this anywhere. What is the
"pro" way to do things? If I try and get proper treble and bass thru my
board and monitors, then isn't that adding to much bass and treble,
because when I then listen to it on my home reciver or car stereo, it
has too much bass and treble because the bass and treb are already
boosted on those systems, which is how most people adjust their home
stereos, car stereos, boom boxes, etc. Or, do I try and mix
comparitively to "flat" CD's thru my board and try to make my
resordings sound equally flat? I'm confused.
 I don't really know much about headphones, but you'd probably have to shell out $100 bucks... Talk to the people in your favourite pro music shop.
