Basic Compressor Question
  • Thread starter Thread starter EightMilesHigh
E
EightMilesHigh
Member
This is probably a borderline newbie question, but since it is about compressors I decided to put it here. I record with a KORG D1600, and have never used any external compressor. I have instead added compression to the already recorded tracks (on the system). What difference would adding a good external compressor to my set up make? I read someone say it could be used to “pump or control dynamics.” I am not entirely sure what this means.
I'm really new with compressors and that whole sha-bang. But I think i can tell you what the person means when they say " you can use compressors to pump or control your dynamics ". Compression can be easily overdone in which it will result in a pumping sound within your mix. Pumping is a bad thing. Or you can use your compression wisely to control the dynamics of your recording. Hopefully I'm not steering anyone off course with this. good luck , ill keep up with this post as I have much to learn about compression.
I would learn to use a software compressor properly first - you'll know when you need a good outboard comp.
Erockrazor said:
Pumping is a bad thing..
Not nessesarily, too much or bad pumping is bad. I've read that even the biggest of pro engineers prefer a little pumping/breathing in time with the song.
compression will also raise the noise floor of the keyboard up . Use it carefully because before you know it you might end up with a lot of hiss.
