Basement Drum Studio Build Diary
  • Thread starter Thread starter XeroTalent
X
XeroTalent
I normally rehearse in my basement, which was completely bare concrete foundation - no studs, ceiling, fixtures, etc... just bare concrete and floor joists for the first floor, as you can see from an older pic of my setup:
Since there was no drywall, insulation or ceiling, the drums were LOUD in the house. My wife was super cool about it though, and often I would practice while she was out. At the very least, she couldn't do much if she was home while I was practicing - watch tv, listen to music, etc.. just because it was so loud.
And then we got a little puppy. I tried playing a couple of times, but our poor Beagle gets terrified...
So I basically haven't practiced much in my house since getting our puppy in August, unless she was outdoors. This gave me the motivation to start my basement reno, which had been on the backburner since buying our house in 2009.
I started renovations and started building my studio in my basement over the Christmas break. Anyway, here's a little build diary of my progress.
Unfortunately, I have no "before" pics. As I mentioned, the basement was completely bare to the concrete foundation. No walls or studs, completely bare.
This was taken at the end of the first weekend of work. Partition wall built - through that doorway is the studio area. The other room (in which I was standing for the pic) will be a party/bar room. Where that orange chair is will be a storage closet, and access to the furnace room.
To the left of the door, where the garbage can is will be framed with a door for another storage closet under the stairs.
Studs framing the party/bar room
Studio side - partition wall, and the wall that boxes in the furnace. Duct work framed for boxing. All my drums and recording gear boxed up :(
Studio side - soundproofing added to the partition walls, started drywall on the duct box so I could measure up the door for installation. Pot lights and switches all wired up, 2 additional outlets added to the room. Electrical is now finished.
Studio side - soundproofing finally done last night. All the walls are done, and the ceiling has a double layer of acoustic foam. Ready for drywall now. Quiet as fuck, can't hear shit!
That nook on the left will be my mixing station, where I'm building a built-in desk, with a library wall (I have a lot of books!)
More pics to come! Up next, drywalling.
Man...awesome start! I'm not sure of your age, but I'm guessing I'm in the same life boat as you! Married in 2010, bought first house in 2009, "installed" a studio, have a bar room and live/jam room downstairs, have a young dog, and will be moving soon (when we find the house that's right for us. eg: for me it's the basement!). So this post is invaluable to me! Since I plan on having a completely closed off room as well for drums, AND a bar room in our new house. I've been contemplating just how far I will go with soundproofing (I am also a drummer so things get loud), and I have been thinking I'll probably only have the time/budget to do something like what you've done. Room within a room just wouldn't cut it. Too small inside (if you do it in a standard basement).
So I'm first off glad to hear that it's quiet as f*ck and that you can't hear sh*t outside the room! :p
Keep up the good work and I look forward to seeing the progress. I too will post a diary come time to do so.
Cheers!
Hey fellow Ontario resident! I'm 33 years old :)
So far, I've spent about $1400 in materials, which is great. That includes the drywall, studs, acoustic insulation, thermal insulation, and electrical stuff (fixtures, outlets, wire, marrets, etc). I have about $600 left, which I have to finish the bar side. That will likely go into the remaining drywall and whatever I'm going to use for flooring (likely laminate). I'll burn through my $2000 budget and see how far I get. Worst case, I'll be using rugs on the floor (which is the concrete foundation right now) until I save the money to finish the floors.
I like the industrial look but yeah all those hard surfaces will be hard to tune. Planning on rigid insulation and bass traps?
What is the ceiling height?
Nice looking kit too.
Got anything you can let us hear?
Bass traps for sure in the corners. Otherwise, no extra insulation. Drywall is next, then another layer of QuietRock for the ceiling. That should be sufficient for my home practicing. I'm making some 2'x2' panels that I can hang on the wall as needed.
The ceiling height is 7'2", under the duct box is 6'4" I believe.
I have a bunch of stuff on SoundCloud, mostly live recordings from gigs but a few other home studio stuff: https://soundcloud.com/xero-talent
And this is my last recording at home before I packed everything up to reno: Gamberg Vs Bourne - Bourne Legacy Theme (With Drums) - YouTube
That video kicks ass. I say you're close to done right now.
Thanks for checking it out :)
Yeah, getting there. Once the drywall is up and plaster done, then that's the worst of it. The desk build, painting and finishing touches (molding, etc) should go fairly quickly.
Finished framing the closet. Didn't get as much done this weekend as I wanted.
Looks like my basement a number of years ago in the early stages of a studio build.Have you considered using 'Resilient Channel' and MDF board before installing the drywall?I bring this up because by doing so you will increase your soundproofing by leaps and bounds.Can tell you from experience that you will not hear much if any sound in the upper levels of your home.
The following videos show my studio build.Hope it may help you in some way.
Part 1 Sanctuary Studio Control Room Build - YouTube
Part 2 Sanctuary Studio Live Room Build - YouTube
I'm using a layer of QuietRock and then a layer of drywall for the ceiling. I figure that should be good, but I may use your technique on the walls!
Going to check out your build now :)
Overdue update....
Plastering and sanding done. Sanding = worst ever.
Ready for paint.
Finished for now. I still have some work to do:
- Finish the back corner once the foundation leak is fixed when the ground thaws
- Moulding,
- Floor
- Make some acoustic baffles
I'm done working for now, and I'm just going to enjoy using the room for a while. When I get the motivation, I'll tackle the remaining bits.
Dude! :drunk:
Very cool and much props.
How's it sound? Ya get the iso you were lookin for?
Does your beagle still get freaked? :p
Outstanding job, sir... but I noticed your cymbal stand is out of it's spot. :mad:
Let's get that squared away, hmmm?
:D
