F
freakkguitarist
construction on my basement is going to start this month and im curious as to what would be best. i know hard floors are better then carpeted floors, but what about the walls. i know idealy non parallel walls would be best. we CAN do that to my basement, but it would cost alot more. would putting up some foam/diffusers/absorbers work just fine? the basement is going to be devided into 3 seperate rooms,
control room
vocal/amp room
drum/live room
what conditions should i be striving for, for each room? since the basement is cement floor, and cement walls right now, i can do anything, but the CHEAPEST way possible is needed
control room
vocal/amp room
drum/live room
Ok, what is your plan. Or do you have a plan yet. One thing you do NOT want to do with this sort of construction is fly by the seat of your pants. Room treatment is afterthe fact, but isolation success depends on PAYING ATTENTION TO DETAILS. And you can't detail something if you have no plan. Many things have to be taken in to consideration. Room height, doors, jambs, glass, seals, hvac, air gaps, acoustical sealants, thresholds, latches, blocking, resiliant isolators, and many other little details....like they say, the devil is in the details.
