kip4
will somebody please outline the process for bandpass EQing
the more detail the better
Im using cubase thanks
Select your desired low rolloff frequency, filter type and slope, select your desired high rolloff frequency, filter type and slope.
But bandpass filtering is more for things like speaker crossovers and that telephone/AM radio effect than for any normal eqing.
...exactly how to do that... in Cubase... in as much detail as is even possible
If the exact answer to your exact question is something you already know, did you just want to see who would waste the most time answering it, anyway? I guess I won, huh?I got that thanks and i am aware of how to acheive bandpass in an eq.
you posted
Agreed. That's definitely going on, too. It's really all the normal tricks for making something sound old and somewhat low-quality. Over-compressed, bandpass EQ, slightly distorted
are you applying the effects in this order and please prey tell what distortion is best for this effect
thanks
ChuckDuffy are you using the bandpass filter followed by the plate reverb on just the vocals?
Sounds like there is distortion on the vocal, and a high pass and low pass, so its more just the mids coming through. You can try boosting the mid range also to add distortion but this can be risky as you can end up with a harsh sound rather than a smooth distortion.thanks for the response guys Actually this post was in response to another.
https://homerecording.com/bbs/general-discussions/newbies/how-get-vocal-sound-341274/
How do i best achive this if its not a dumb question
