R
Richard Monroe
Thanks heaps for all the advice here. Got a couple of questions for you if you don't mind...that Behringer V-amp you mention, I'm guessing the V stands for virtual, as in, you don't need a 'real' amp? If so it might just make an electric guitar/amp set up within my price range. I don't do any live playing, so just need to be able to hear myself and record really. How does this device interact with a USB interface? Do you plug it into the MIC in?
Thanks again.![]()
The current equivalent is VAMP III:
Behringer V-Amp 3 | 8thstreet.com | Call 1-800-878-8882 | Most Orders Ship Free!
It has a built in USB interface out, so you can plug it straight into a computer. Yes, VAMP stands for virtual amplification. If you do a search on amplifier modeling, AKA amp sims (simulation), you'll find it was a hot topic of discussion for quite a while here. The various versions of the Line 6 POD are kind of the industry standard, and I do occasionally use an old POD Pro 2.0, but for my purposes, the VAMP has more useful models and is a hell of a lot cheaper. I also occasionally use a Bass VAMP Pro. You'll hear several basic positions, as follows:
Argument A, the purist:
"To get that real electric sound, you use real amps and microphones. You crank that bad boy up in a good room and play with levels and placement until you get that Godlike sound. No modeler can ever equal the sound of a cranked up tube amp."
Argument B, the moderate position:
"Cranked up tube amps are really cool, but I don't have the bucks to buy all those boutique tube amps, and plenty of successful commercial recordings have been made using modelers. I'd really prefer to crank up an amp. Send me one. In the meantime, I'm using sims because it doesn't wake up the baby and I can practice in my flat anytime without the neighbors complaining".
Argument C, the modeler position:
"This thing is cool. I can make almost any sound I want with it. It just takes time to get the settings right, like any piece of equipment. Besides, a cranked up amp is so loud, it can damage your hearing. Why would I want an amp anyway?"
I don't really subscribe to any of the above positions, but there is some truth to all of them. Here's my spin on it:
Modeling was a really cool idea when the first POD came out. The problem was, it was a technology in its infancy, and basically, it sucked. After a couple of years and redesign, it sucked less. Then, it only sucked a little, then it only sucked some of the time. Now, we're at the point where it doesn't suck as much, or as often, as you think. Personally, I use real amps *and* modelers, and I think they are both useful tools. The first thing is realizing what modelers do worst- simulating a cranked up tube amp with a mic in front of it. What they do best is producing clean tones, whether effected or not. Most electric guitarists use a good amount of distortion, especially lead guitarists. On the other hand, I used to play The Who a lot, especially Tommy, and most of Pete Townshend's tones were pretty clean. Another thing modelers do badly is simulating the sound of air hitting a microphone, generally called "moving air". This is the way electric guitars have been recorded for a very long time, and we have gotten used to that sound.
So- I thought if I took the line out from the modeler, and ran it into a clean power amp and a speaker, I could then put a mic in front of that speaker, send it to a mic preamp, and record it. You can use a small PA for this, or a powered monitor, or a power amplifier and a wedge monitor. This greatly increases the believability of the model, because it's really moving air. I often mix modeled sound with mic-recorded sound, as in the example of putting a mic on a solid body guitar, which I admit is pretty unusual.
All I'm saying is that just because a modeler can be recorded directly, don't think it has to be. Regardless of the Hooey about computer modeling, it's a guitar preamplifier with a line level output. You can record that output directly, or you can send it to a power amp and a speaker, and record it with mics. And, in the case of the VAMP III and the later POD's, it also has analog to digital conversion, so you can send it as digital data direct to your hard drive. No- do not use the mic input on your soundcard. The levels are not compatible, and computer soundcards are not designed for critical recording. In short, your plan should always be to bypass that soundcard. If you have a recording interface, you can just take the line out of the modeler and send it to the line in on the interface.
I use the VAMP a lot for solo gigs, and just jack it right into my PA. It's got banks of presets you can create for different sounds, different songs, and different guitars. If you are just starting, I think a good cheap modeler is really useful, and can be used for lots of stuff. Even after you get the amp from hell, you'll find it has uses as a headphone amp, putting effects on acoustic guitar, and as a creative tool. When I travel, I often carry a Pocket POD, a miniature modeler, just for a battery powered headphone amp for noodling. Bang for buck, the VAMP is a really useful tool and a really cool toy.
