jmorris
I'll just give you an example of what happened last week. We recorded a song, 15 tracks and in the mixing, the acoustic guitar (which was a great sounding track BTW) would not fit into the mix. On its own, it was a perfect sounding track. Noithing at all wrong with it. In the mix, it needed like all the bass cut and too much boost in the highs to even come close to sitting in the mix. I changed mics from a royer ribbon to a U87 with the same placement and it worked perfect in the mix. So, in the end the track was recorded wrong for this particular song and mix. Like I said before, professional mix houses cannot re-track a track and they work the SSL's compressors, EQs, pads and everyother imaginable tool to make a good mix. If a band has a good producer and they will oversee the tracking, and mixing (most great producers do) then they make the artist re-record tracks that just need too much work. A good video is Joe Satriani's studio video. Glynn Johns made him re-take every guitar track performed exactly the same while he was working along. He tracks and mixes along the way and stops when there is a problem. Not everyone will do this but it is the right way to do it if you have the $$$ (or time for the homereccer).
Find the interview with RUSH. It is interesting because they scrapped the album and started new because of lousy mixes happening.
And in the end, we all do it our own way. I would rather re-track than put all three of my racks of tools to fix a track that does not fit into a mix.
BTW, my new project has some songs that were totally re-recorded up to 5 times (all except the drums). After all is done, I listen days later to the first mix and the last mix (re-recorded tracks) and the difference is amazing.
Hum! Interesting I'll check out the Rush thing and the Satriani. I guess the thing Im getting hung up on is the term "incorrectly". If a recording,say acoustic guitar,sounds great while listening to it solo'd on playback, then it was not recorded incorrectly. BUT,I do understand your point you are making. The other thing with regard to the term " correctly recorded" I cant imagine telling a client after days or months of tracking,and in the middle of mixing that we need to re-record some tracks as they were not "recorded correctly" and then charge them for it.You take that approach and you'll be in a bad position.
) But to record tracks yourself,enter the mixing stage and days later say to band'you know, some of these tracks were not recorded correctly,we need to re track them and Im going to charge you" does not fly. Yes, inexperienced band you may have to track many times. But, that is not a "incorrectly recorded" thing.
